Can't define PVE Uplink with srw224g4
I tried to  setup sample usage of PVE with Linksys  SRW224G4 withot success. I successfully set PVE g1 for ports 1 to 5 but I can't setup uplink port for this PVE group. I can't find place where can define PVE mapping an PVE upllink in web view. When I googled about this  I find that in "Port config" section in firmware version befor 1.2.2 have "pve mapping", but there is not such link. How can i define Uplink for particular PVE group in firmware version before 1.2.2?
Thanks in advance
1 REPLY
Re: Can't define PVE Uplink with srw224g4
Huh,
Even though i am using older software here, it seems straight forward.
Can I humbly suggest, that you contact the SBSC  to get some phone help, if this switch is still under phone support warranty.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
regards Dave
788
