Cannot upgrade boot code SG500X-48
First of all, i'm sorry for my poor English
I recently received 4 SG500X-48 Switch and 4 SG500XG-8F8T for made a stack whit them. My problem is, i cann't upgrade the boot on my  SG500X-48.
They configuration are:
SW Version: 1.3.0.62
Boot Version: 1.3.0.03
image-1 (active): 1.3.0.62
image-2 (not active): 1.3.5.58
I have read on multiple forum, for upgrading to the last version of firmware (1.4.1), you need to have a boot version 1.3.5 minimum. But when i upgrade the boot code by the web interface by tftp or by commande line, the download start, seems to succes and when i reboot, i have again the 1.3.0.03 boot version...
I have already try to upgrade the boot on version 1.3.7 & 1.4.0 but i have the same disillusionment
If i upgrade firmware on 1.3.5 and i upgrade to boot code to version 1.3.5 or 1.3.7 or 1.4.0, i have the following message:
Boot version is too old !
Any idea ?
Thanks for helping.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Hello, I'd suggest you re
I'd suggest you re-flash your firmware with another firmware version 1.3.5 or 1.3.7 then set it as your "active" image. Re-attempt to do the tftp transfer of the bootcode after and perform a reboot.
Also, double-check that the firmware files you're using are not corrupted by checking their MD5 hashes. (MD5 hash of 1.3.5.58 zip file is 3f791574eb10db515251b83e6965a1c5J)
Hope this helps.
Hope this helps.
Hi, It seems working... I
It seems working... I have change the tftp programme (tftp64) ,re download the firmware files here:https://software.cisco.com/download/release.html?mdfid=284099563&softwareid=282463181&release=1.2.0.97
I don't know if the files were wrong (i have used them once month ago) or the program tftp but now it's working.
And now, my boot version is 1.5.0 :D
Thanks you for your help !!
126
