Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
cisco 500 series switches
Dear support,
Can Cisco 500 series switches deliver 24V on the access port for POE operation?
Best Regards
a kind reminder
Green
Hi, the SX300/500 supports 15.4 watt.
So if you have 24 V, with 2 amp, that is 48 watt if it is DC.
AC three phase with 24 V, 1 amp and power factor of 1 is 41.5 watt.
AC one phase with 24 V, 1 amp and power factor of 1 is 24 watt.
So I would say no it is not supported.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom,
thank you for your reply. but as per the below datasheet, the 500 series switches support up to 30W/port, kindly advise..
http://www.cisco.com/en/US/prod/collateral/switches/ps10903/ps12128/c78-695646_data_sheet.html
best regards
a kind reminder
Dear Support,
kindly advise which switch can deliver 24V on the access port for POE operation?
please treat this case as an urgent matter as i need to get back to my client asap
I belive the 802..2F and 802.2at poe standard is strictly 48v.  I haven't found anything to the contrary.  There are inline convertes 48v-24v or something like this that can be used with a non poe switch: http://www.digital-loggers.com/poe24.html but that means all conected device would be off the same access port / vlan.
531
