03-26-2014 07:59 PM
I tried to add Cisco SG300-28 into Spicework but it doesn't work at all.
Firmware:
SW version 1.3.7.18 ( date 12-Jan-2014 time 18:02:59 )
Boot version 1.3.5.06 ( date 21-Jul-2013 time 15:12:10 )
HW version V01
Switch log:
2014-Mar-27 09:05:06 Warning %SNMP-W-SNMPAUTHFAIL: Access attempted by unauthorized NMS
2014-Mar-27 09:05:06 Warning %AAA-W-REJECT: New ssh connection, source 10.2.101.13 destination 192.168.100.25 REJECTED, aggregated (2)
2014-Mar-27 09:04:32 Informational %AAA-I-DISCONNECT: User CLI session for user cisco over ssh , source 10.2.101.13 destination 192.168.100.25 TERMINATED. The Telnet/SSH session may still be co nnected.
03-31-2014 09:48 AM
Hi Max,
I see here you try to connect to SNMP program and this program use SSH. I like to see your config file and I will try it with my own switch. Also about Spicework, it is free program?
Moh
04-01-2014 12:54 AM
I will send switch configuration to your email.
please kindly provide your email address.
Yes, Spicework is a free program.
Spicework download link below
http://www.spiceworks.com/download/
Thank you very much.
04-01-2014 07:58 PM
Hi Max,
Could you do show run and copy SSH and SNMP sections and port them here?
Moh
04-01-2014 08:43 PM
config-file-header
bkk-sw-25
v1.3.7.18 / R750_NIK_1_35_647_358
CLI v1.0
set system mode switch
ip ssh server
ip ssh password-auth
ip ssh pubkey-auth auto-login
crypto key pubkey-chain ssh
user-key admin rsa
key-string row AAAAB3NzaC1yc2EAAAADAQABAAAAgQDFMQiPsbOX
key-string row MMNocuKtdU2H/YOJvyZrDHrOennUGSGdffOCHBMg
key-string row v22OPzzO5fci3JTTv/Gck5Eo6HxadTjEQPgdqoxH
key-string row qoKZeLkASgVQ+ww4/uFHOYowX7xCN4kf
key-string row fxHCYiMCiHY23IVx6TYl8Yf9vWTf0q6N0WTd9/8j
key-string row 5h/U0yN6FQ==
exit
exit
snmp-server server
snmp-server engineID local 8000000903b8621fd588eb
snmp-server location "IT ROOM"
snmp-server community ciscosg300 ro view Default
snmp-server host 10.2.101.13 version 3 auth administrator udp-port 161
snmp-server group spicework v3 auth notify Default read Default write Default
encrypted snmp-server user administrator spicework v3 auth md5 jblmaMDCgbwhZ7DbT6DjE40YbGf6uBm1N12M7Xb6TZ0=
ip http timeout-policy 1800 http-only
no ip http secure-server
clock timezone ICT 7
clock source sntp
sntp unicast client enable
sntp unicast client poll
sntp server 10.2.101.1
interface vlan 1
no ipv6 address autoconfig
no ipv6 enable
no ipv6 dhcp client stateless
interface vlan 5
name VLAN_GUEST
interface vlan 10
name VLAN_LAN
interface vlan 20
name VLAN_MEDIA
interface vlan 30
name VLAN_WIFI_PUBLIC
interface vlan 40
name VLAN_ISP1
interface vlan 50
name VLAN_ISP2
interface vlan 60
name VLAN_TEST1
interface vlan 70
name VLAN_TEST2
interface vlan 100
name VLAN_MGMT
ip address 192.168.100.25 255.255.255.192
interface gigabitethernet1
storm-control broadcast enable
storm-control broadcast level kbps 3500
storm-control include-multicast unknown-unicast
port security mode max-addresses
port security discard
spanning-tree bpduguard enable
switchport mode access
switchport access vlan 30
lldp med enable
interface gigabitethernet2
lldp med enable
interface gigabitethernet3
switchport access vlan 10
lldp med enable
interface gigabitethernet4
lldp med enable
interface gigabitethernet5
lldp med enable
interface gigabitethernet6
lldp med enable
interface gigabitethernet7
lldp med enable
interface gigabitethernet8
lldp med enable
interface gigabitethernet9
lldp med enable
interface gigabitethernet10
lldp med enable
interface gigabitethernet11
lldp med enable
interface gigabitethernet12
lldp med enable
interface gigabitethernet13
lldp med enable
interface gigabitethernet14
lldp med enable
interface gigabitethernet15
lldp med enable
interface gigabitethernet16
lldp med enable
interface gigabitethernet17
lldp med enable
interface gigabitethernet18
lldp med enable
interface gigabitethernet19
switchport access vlan 60
lldp med enable
interface gigabitethernet20
lldp med enable
interface gigabitethernet21
lldp med enable
interface gigabitethernet22
lldp med enable
interface gigabitethernet23
switchport access vlan 40
lldp med enable
interface gigabitethernet24
lldp med enable
interface gigabitethernet25
switchport access vlan 50
lldp med enable
interface gigabitethernet26
lldp med enable
interface gigabitethernet27
storm-control broadcast level kbps 50000
switchport trunk allowed vlan add 5,10,20,30,40,50,60,70,100
lldp med enable
interface gigabitethernet28
lldp med enable
exit
ip default-gateway 192.168.100.1
encrypted ip ssh-client key rsa key-pair
12-12-2014 06:36 AM
Hi, did you ever got this working? Looking for the same thing.
Also tried alternatives via Putty and input files to automate backups of these devices.
So far without luck.
Remko
12-15-2014 07:03 AM
Hi Remko,
I guess Jody answered your question.
https://supportforums.cisco.com/discussion/12375366/login-ssh-without-user-name-and-password
Automatic login was added only with 1.2.9 release.
Aleksandra
