Cisco SG500X-48P
I have a SG500X-48P which connects to a number of SG300 via fibre ports, I have upgraded the 500 to 1.3.0.62 and now we find the switch will not boot up with the fibre modules in, it goes through the process and then comes up with a "fatal error" , then it reboots, its fine if we boot up without the fibre modules in, if we use the other (old image 1.2.7.x) it boots fine with the fibre modules in.
Is there a know software image,
1 REPLY
Green
Cisco SG500X-48P
Hi A.burchell. I cannot reproduce the behavior using 10 gig connections. Best I'd recommend is make a config file back up, factory default the switch and see if it boots up normally.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
229
