Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
cisco sg550xg-24t connected to safenet cn4020
I have two cisco sg550xg-24t's which is need to connect to two safenet cn4020 encryptors.
I have connected the devices however the leds on the switch dont appear to light up and under the ports it shows that the port is down.
I have connected the safenet devices together via a crossover cable and they appear to work correctly however when i connect them to the switch it doesn't bring up the interface.
Is there something i could be missing ? I'm aware that these switches use 'smart ports' which is have tried turning off however this doesnt make any difference , i also noted that perhaps the switch needed it's MTU value for the port lowered however there is no option to do this.
Any other troubleshooting tips would be appreciated!
John
20
