Community Member
Cisco SGE200 password break
I have a Cisco SGE200 which is part of a LAN. The whole switch comes under a VLAN. I have systems connected to it accessing other VLANs and the Internet. However, I have forgotten its user credentials and am not able to login. Since it doesn't have a console port, what is the procedure for breaking the password?
Kaushik
1 REPLY
Green
Hi Kaush, if the password is
Hi Kaush, if the password is unknown, unfortunately the switch needs to be factory default reset.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
96
