Cisco switch sf302-8 config as DHCP client
                 Hello, I have modem asi DHCP server and I reserve address for switch 172.16.2.254. I need config this switch as DHCP  client to the server requested the address.
Can anyone advise me the steps to set the switch
Martin
1 REPLY
Green
Hi Martin, in the default configuration, the switch is designed to get a DHCP address on the default VLAN (VLAN 1). So if the switch is brand new... it will get DHCP unless there is something wrong with the DHCP service.
If you want to modify the existing switch config so that your switch gets an IP address instead of using a static IP you can change this.
From the CLI
config t
int vlan 1
no ip address
ip address dhcp
From the GUI ->
Ip configuration -> IP V4 interface -> Delete the current entry
This will drop connection to the switch and reset the IP address to 192.168.1.254
Ip configuration -> IP V4 interface -> Add new entry and choose dynamic.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
325
