Compatibility of MGBSX1 with GLC-SX-MMD
My query to all of you is;
If I connect a GLC-SX-MMD on a Cisco 2960S switch at one end and MGBSX1 on a SG300-28 SMB switch at the other end, will the link come up? Are these different types of modules interoperable?
Can I use VLAN truncking through this link betwnne these two different switches?
Everyone's tags (2)
1 REPLY
Green
Re: Compatibility of MGBSX1 with GLC-SX-MMD
Hi Pathum, the MGBSX1 is the equivalant of the GLC-SX-MM. I am not sure the MMD is compatible but I am thinking so long as you're using the correct patch cable (MM) and your backbone is MM it should be ok.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
1634
