Configure SG500X using Cisco Configuration Assistant (CCA)
cm.netatvision
I have a couple of SG500X Switches which need to be configured and I wanted to do this with a central managed tool to have an uncomplicated way to configure the switches.
I already found Cisco Configuration Assistant, which supports the 200 and 300 Series but does not seem to support 500 Series. Also I found the Cisco Network Assistant which only supports Catalyst Switches.
Is there a tool which can be used to centrally configure and manage SG500X switches?
Thanks in advance,
Christoph
cm.netatvision
push
Is there really no tool for the 500 Series?
Seems strange to me, as 300 and lower have the CCA and Catalyst have CNA, only the 500 don't have any tool.
