CONFIGURE VOICE DATA ACCESS PORT SW SF500-48
Hi Everybody,
I have a SW SF500 small business and i need configure one port how access for Voice and data VLan. I need help with any configuration that can apply por this requirement. I attach the design that i hope to work
Thanks in advance
1 ACCEPTED SOLUTION
Hi Acruzgreg,
Best practice if you want to manually configure this is to set the interface as a trunk with the voice vlan tagged and data vlan untagged.  In order to get the phone on the voice vlan you will also need to manually set the admin vlan as the voice vlan in the phone.
A better way would be to setup Auto Voice Vlan on the switch (if the phone supports CDP).  So that the voice vlan id is sent to the IP phone.
Let me know if you have any further questions,
-Trent Good
-Trent Good ** Please rate useful posts! **
Hi trent,
thanks by you response,
I have 40 iphones cisco, and I would like to  be transparent for the ip phone and PC, I think that te Auto Voice vlan is the correct setup . Do you have any configuration guide or link to setup this?
- regards
thank you Trend,
regards
855
