12-30-2015 03:24 AM
may someone can help me. I'm struggeling since 3 days with our VLAN configuration. I don't know where is my error in reasing.
Attached is out networktopolgy. Problem: I've no connection to the WLAN APs on Switch 1 and 4. WLAN on Switch 2 (where also the routers connected) works perfectly) Whats wrong with the configuration/Tagging?
Hopefully someone can help me!
Regards HES
12-30-2015 03:56 AM
Pls share switches configurations and also network diagram with switches names.
12-30-2015 04:06 AM
Names are from up to down 1-4. What configuration do you need? All Ports marked as trunks.
12-30-2015 07:41 AM
oh man I've found my fault: I had a second cable from switch 2-->3 both ports where untagged -.-
Thanks!
12-30-2015 07:41 AM
Thanks!
12-30-2015 04:35 AM
Have you looked into VTP at all as of yet? Also, are the ports to the APs trunked as well? If you can provide the switch configs that would be helpful.
