12-06-2013 08:01 AM
please forgive the newbie question but trying to upgrade/expand my network beyond the simple linksys switch i currently use.
what is the proper way to connect a second SG300-10P to the system?
current configuration is:
cable modem to Cisco Router RV042G. Router port 1 to SG300-10P port G9 (the switch is located in another room)
from the SG300-10P i have ethernet cables (Cat 5) running throughout the building
in another room, i would like to add another SG300-10P. do i connect from the ethernet jack in that room to port G1-G8 or do i connect to the G9 link port?
thanks
Solved! Go to Solution.
12-12-2013 07:50 AM
Hi Lee, you may interconnect on any port you like. I would recommend to disable POE on each interconnecting port between the switches though.
-Tom
Please mark answered for helpful posts
12-12-2013 07:50 AM
-Tom
12-12-2013 08:16 AM
thank you.
in general, should POE be disabled on any port not requiring it or does it not matter?
12-12-2013 12:33 PM
Hi Lee, it generally doesn't matter. The reason it matters interconnecting these switches is because the POE is designed to work with older Cisco POE devices and the connection will detect a valid resistance and attempt to supply power to the switch which in turn may give adverse affects.
-Tom
