08-27-2014 07:03 AM
I am having some serious connectivity issues between the hosts in my LAN.
My LAN is based on a Cisco 2901 router and a Cisco SG300-52 port switch.
The issue that has been happening is that connections between hosts on the LAN (remote desktop, extended ping, etc) is very unstable, at some point I can see a 35% lost packets on an extended ping. This happens at any time of the day and from any host.
All hosts are on the same Vlan(default Vlan) and on the same subnet. Some hosts have fixed IP addresses (servers and network equipment) and others obtain their IP address trough a DHCP reservation established on the router (reserved with the MAC address of every host).
I can provide further details if needed, because this issue is very serious and I would really appreciate any insight or support.
Many thanks in advanced.
Sair Amer
EDIT: After doing every test we could think of, we finally found the reason behind this problem.
It turns out that the switch has problems handling communications between clients at different speeds, because most of the hosts connected were working at 100 Mbps but the servers were working at 1000 Mbps (and the communication between host and servers wasn't stable).
After manually setting the speed on all ports to 100 Mbps the problems have stopped.
Many thanks for you help on this issue.
08-27-2014 07:42 AM
Do you see loss of pings if you ping from 2901 to your switch IP address? Check logs and see if any errors are there.
08-27-2014 09:03 AM
Hi Michael,
Thanks for your quick reply.
There is some ping loss if I ping from the router to the switch. However the loss percentage is a lot smaller that if I ping between hosts in the network.
I reviewed the error logs, and there are no errors in the router's log.
On the switch I found some errors but only in the flash memory error log, the message is the following:
%CDB-E-VARNOTSUPPORTED
This error is repeated many times with different values of the MIB variable.
What do you think this could mean?
I should also mention that I tried to update the firmware of the switch via HTTP but I got the following error:
illegal software format.
I tried to update the boot loader first but gave the same error mentioned above.
Many thanks in advanced for your input.
Sair Amer
08-27-2014 09:16 AM
Were you having issues before trying to upgrade? It may be best to contact Cisco Small Business Support. Whatever is generating those log messages could be overloading that switch causing dropped packets. Do you have another switch you could test with?
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
08-27-2014 09:22 AM
Michael,
This issue has been going on before the attempt to upgrade the firmware.
I have tried to contact Cisco support but their telephone number does not work(I am currently in Chile) and their live chat also does not work.
I tested with another switch (non-cisco) and the error continues.
Do you have any suggestions on how to test if the router is the faulty equipment? (I do not have any other cisco router, only a small household type router).
Thanks again for your help.
Sair Amer
08-27-2014 09:35 AM
Post your running configuration and I will take a look. If it is some sort of hardware issue on the router your best bet is calling TAC.
08-27-2014 11:48 AM
Building configuration...
Current configuration : 4123 bytes
! Last configuration change at 12:06:16 PCTime Sat Jul 19 2014 by ccp
version 15.2
hostname Foninsa
boot-start-marker
boot-end-marker
no logging buffered
enable secret 5 $1$BDbJ$HN3VP8nmywrGB55RCxPd30
aaa new-model
aaa authentication login default local
aaa authorization exec default local
aaa session-id common
clock timezone PCTime -4 0
clock summer-time PCTime date Apr 6 2003 2:00 Oct 12 2003 12:00
no ip cef
ip dhcp excluded-address 192.168.1.1 192.168.1.10
ip dhcp excluded-address 192.168.1.151 192.168.1.255
ip dhcp pool FONINSA
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
dns-server 8.8.8.8 8.8.4.4
ip dhcp pool Laptop-Sporta-Wifi
host 192.168.1.10 255.255.255.0
ip name-server 8.8.8.8
ip name-server 8.8.4.4
no ipv6 cef
crypto pki trustpoint TP-self-signed-213585710
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-213585710
revocation-check none
rsakeypair TP-self-signed-213585710
crypto pki certificate chain TP-self-signed-213585710
certificate self-signed 01
30820229 30820192
quit
license udi pid CISCO2901/K9 sn
license boot module c2900 technology-package securityk9
username ccp privilege 15 password
redundancy
interface Embedded-Service-Engine0/0
no ip address
shutdown
interface GigabitEthernet0/0
ip address 190.196.21.98 255.255.255.248
ip nat outside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0/1
ip nat inside
duplex auto
speed auto
no ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip nat inside source list 1 interface GigabitEthernet0/0 overload
ip nat inside source static tcp 192.168.1.3 21 190.196.21.98 21 extendable
ip nat inside source static tcp 192.168.1.3 80 190.196.21.98 80 extendable
ip nat inside source static udp 192.168.1.8 1194 190.196.21.98 1194 extendable
ip nat inside source static tcp 192.168.1.4 3389 190.196.21.98 3389 extendable
ip nat inside source static tcp 192.168.1.9 3389 190.196.21.98 10000 extendable
ip nat inside source static tcp 192.168.1.3 3389 190.196.21.98 20000 extendable
ip route 0.0.0.0 0.0.0.0 190.196.21.97
access-list 1 permit 192.168.1.0 0.0.0.255
control-plane
line con 0
password $
line aux 0
line 2
no activation-character
no exec
transport preferred none
transport output pad telnet rlogin lapb-ta mop udptn v120 ssh
stopbits 1
line vty 0 5
access-class 23 in
privilege level 15
password #
transport input telnet ssh
no scheduler allocate
end
08-27-2014 12:41 PM
I don't see anything jumping out. You may try upgrading the IOS and see if that helps. If you have the ability I would open a TAC case.
08-27-2014 06:04 PM
Hi Sair
Have you done basic troubleshooting?
1. Check speed duplex
-on router do "show interfaces <port>" in the SG, navigate throug GUI and change that port
-Make sure devices are in their optimal setting, ex: 100Mbps/Full-Duplex
If speed and duplex are different try hardcoding it
2. Check the cable
-The problem might be in the cable, try replacing it
3. If issue still persist,
-Try allocating another port on the switch to the router
