Community Member
Dashboard
When i log into the Cisco Switch, the configuration utility comes up, but I can't access the dashboard.
1 REPLY
Silver
If you are talking about the
If you are talking about the Web UI based management, you are probably missing Java
Also, don't forget to configure username/password as well as login local in your line vty configuration
74
