06-09-2014 05:42 AM
I've create 2 vlan in a cisco SG500X-24 and a DHCP server on vlan 2. I just want to dhcp server assign ip to devices on vlan 3. I've configured the vlan and dhcp server relay commands.
ip dhcp relay address 192.168.1.11
ip dhcp relay enable
ip dhcp information option
interface vlan 2
ip address 192.168.1.250 255.255.255.0
interface vlan 3
ip address 192.168.51.254 255.255.255.0
The dhcp server gets the request from pc, and sends a new address, but the offer packet not comes to device. With Wireshark a see like offer dhcp packet can't jump to vlan 3.
It's the first time a work with SMB series, and this never happens with catalyst. I'm turning crazy.
Anyone can help me? Thank you in advances.
Victor.
06-12-2014 09:17 AM
Hi, did you also configure the DHCP relay on the switch interface? I see you have global option set but I don't see port configuration done.
06-13-2014 01:32 AM
Yes, also I configured ip dhcp relay on intefaces.
Yesterday I found the trouble. I was using the tftpd32 dhcp server, and I tested with a Windows DHCP server and everything works like a champ. I didn't know what have do, and i turned crazy, so I began to change every element on solution, finally the DHCP server that it was the key.
Thank you so much for your answer.
KR!
