dhcp sg300 vlan
Okay. I have two scopes for two vlans configured on the sg300. When I put my laptop in vlan 1 I get an ip from 192.168.0.0/24. I then release the ip, I put the port my laptop is in into vlan 20 and try to renew to get an ip from 172.20.20.0/24 subnet associated with vlan 20 but I get an ip from 192.168.0.0/24 which is associated with vlan 1. The only way to get this to work is I have to go into the sg300 and delete the dhcp binding and then renew and I then get an IP address from 172.20.20.0. I would have thought that if I put the laptop in vlan 20 and released and renewed the sg300 would give me an IP address from 172.20.20.0 not 192.168.0.0 which is associated with vlan 1. What am I missing? Why is the sg300 responding with an ip from different vlan?
  • Small Business Switches
2 ACCEPTED SOLUTIONS
dhcp sg300 vlan
I've also experienced this and there was a similar post unanswered this month I believe.  It may not be considered a bug or a problem since hosts aren't expected to change vlans like they do when we use are PCs for testing.  Personally I would think that each vlan would have it's own isolated binding table as well as every other table, array or structures.  Maybe some one can explain a solution or the reason why this is normal.
Green
dhcp sg300 vlan
I would suspect the ARP did not time out.
Reduce the ARP timeout for testing purposes then let enough time elapse then release/renew or disconnect/reconnect from the physical port.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
dhcp sg300 vlan
Green
dhcp sg300 vlan
-Tom
Re: dhcp sg300 vlan
Where is that setting configured? However my initial summary does seem like a bug. I opened a TAC case
Re: dhcp sg300 vlan
This turned to be a bug and will be fixed in the next software update
723
