Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
ESW 520 & 540 PoE capabilities
Could you please help me to know the exact number of ports that can be powered at the same time using the PoE capabilities of the ESW-500 family switches?
I mean in the 24 and 48 ports models, the total amount of the ports (24 and 48 ports) can be powered at the same time or the swithces are limited to power only  a specific amount of ports simultaneously  which is less than the total density of the ports ????
Thanks in advance for your support.
Best Regards///Hugo.
1 REPLY
Re: ESW 520 & 540 PoE capabilities
Please refer to Table 3 of the attached ESW 500 Series Q&A Document.
575
