Community Member
ESW Switches
Cisco Guys,
Here are a few things things / suggestions on these switches...
1) ESW 540 8P - it would be great if you could make the form factor bigger to have an internal power supply.
2) CCA 2.2.1 - Doesn't have all the port roles in for the ESW switches
3) VLAN's are less desirable to setup through the web interface (see point 2)
4) Port numbering... Can we look at setup of the port numbers to be the same as the non ESW switches.  For example have the ports not 1,2,3,4 but 1,3,5,7.  Consistency is king.
I think these will be a nice step past the linksys heritage.
Thanks Guys!
Everyone's tags (1)
Re: ESW Switches
Hi Chris
I will forward the feedback to the product manager (PM).
i really like the idea of internal power supply for the ESW540-8P, especially if it is going to be rack mounted.
Good luck on the port re-numbering
but I'll pass it onto the PM.
I believe the next version of CCA is due out this month, will have the expanded smartport roles, but i guess you got around that today via the ESW GUI.
regards Dave
