04-26-2012 09:29 AM
I need a switch that does not have nickel plating, which some RJ45 connectors have. the SF100D-16 appears to have black RJ45 jacks, which would point to a non-nickel plating. does anyone know what material the RJ45 connectors and housing are made of?
Thanks!
Solved! Go to Solution.
05-08-2012 08:43 PM
Hi Scott,
Just noticed your posting, Can you please send me your contact details to my email address below, we'll see if we can get an answer from the Product Manager;
dhornste at cisco.com ( remove the spaces and replace 'at' with @ )
05-08-2012 08:43 PM
Hi Scott,
05-17-2012 11:53 AM
In case anyone ever has this bizarre requirement, The product manager said that there is no nickel plating used on this switch model. Thanks to Tori at Technical Support for her help!!
05-17-2012 11:54 AM
In the following months Great Basin College will be moving its email from Groupwise to GMail. Would you please update your contact information for me to dj.smith@gbcnv.edu. Thank you and have a Great Day!
