factory defaults
hello I have 2 SLM248G4PS that i need to set back to the factory defaults,
however i don't have access to the GUI interface, when i try to launch it it won't open because the default gateway was set to an ip that is in use by a device that we can't re-ip.
i need to set those 2 switches back to the defaults and start the config from scratch
thanks
Cris
1 ACCEPTED SOLUTION
Re: factory defaults
thanks
Cris
Hi Cris,
Try configuringusing console connection see the attached document for step by step procedure !!
Ganesh.H
Remember to rate the helpful post
1 REPLY
thanks
Cris
Hi Cris,
Ganesh.H
489
