How do I add a line into an access control list?
We have a user VLAN that allows connectivity to printer VLAN.  Printers connect and need snmp to communicate.
New printers were brought in, and they need port 443 opened.  I was under the impression I could insert a line into an ACL(below).
I have copied the production ACL to this test ACL (102) and it works fine when I changed the VLAN interface to use this ACL.  I copied and pasted, however, and the new ACL was easy to create and apply.  Since I have 30 more production switches to do this to, I was hoping I would not have to delete this ACL and recreate it.  I thought there was a way to "inject" a line into an ACL
Any thoughts?
access-list 102 permit udp any any eq bootps
access-list 102 permit udp any any eq bootpc
access-list 102 permit icmp 10.0.32.0 0.255.3.255 10.0.32.1 0.255.0.0 echo
access-list 102 permit icmp 10.0.32.0 0.255.3.255 10.0.32.1 0.255.0.0 echo-reply
access-list 102 permit icmp 10.0.32.1 0.255.0.0 10.0.32.0 0.255.3.255 echo
access-list 102 permit icmp 10.0.32.1 0.255.0.0 10.0.32.0 0.255.3.255 echo-reply
access-list 102 permit icmp 10.0.32.0 0.255.3.255 10.0.96.0 0.255.0.255 echo
access-list 102 permit icmp 10.0.32.0 0.255.3.255 10.0.96.0 0.255.0.255 echo-reply
access-list 102 permit tcp 10.0.32.0 0.255.3.255 10.0.96.0 0.255.0.255 eq 443
access-list 102 permit udp 10.0.32.0 0.255.3.255 10.0.96.0 0.255.0.255 eq snmp
access-list 102 permit tcp 10.0.32.0 0.255.3.255 10.0.96.0 0.255.0.255 eq 161
access-list 102 deny   ip 10.0.32.0 0.255.3.255 10.0.32.0 0.255.3.255 log
access-list 102 deny   ip 10.0.32.0 0.255.3.255 10.0.64.0 0.255.0.255 log
access-list 102 deny   ip 10.0.32.0 0.255.3.255 10.0.96.0 0.255.0.255 log
access-list 102 permit ip host 10.105.34.9 10.0.112.0 0.255.0.255 log
access-list 102 deny   ip 10.0.32.0 0.255.3.255 10.0.112.0 0.255.0.255 log
access-list 102 deny   ip 10.0.32.0 0.255.3.255 10.0.114.0 0.255.0.255 log
access-list 102 deny   ip 10.0.32.0 0.255.3.255 10.0.161.0 0.255.0.255 log
access-list 102 deny   ip 10.0.32.0 0.255.3.255 10.0.165.0 0.255.0.255 log
access-list 102 deny   ip 10.0.32.0 0.255.3.255 10.0.235.0 0.255.0.255 log
access-list 102 permit ip 10.0.32.0 0.255.3.255 10.0.240.24 0.255.0.0
access-list 102 permit ip 10.0.32.0 0.255.3.255 10.2.240.0 0.0.1.255 log
access-list 102 deny   ip 10.0.32.0 0.255.3.255 10.0.240.0 0.255.0.255 log
access-list 102 deny   ip 10.0.32.0 0.255.3.255 10.0.241.0 0.255.0.255 log
access-list 102 permit ip any any
1 ACCEPTED SOLUTION
Silver
Use show ip-access lists to see the numbering:
R1#sh ip access-lists
Extended IP access list 102
    10 permit udp any any eq bootps
    20 permit udp any any eq bootpc
    30 permit icmp 10.0.32.0 0.255.3.255 10.0.32.1 0.255.0.0 echo
    40 permit icmp 10.0.32.0 0.255.3.255 10.0.32.1 0.255.0.0 echo-reply
    50 permit icmp 10.0.32.1 0.255.0.0 10.0.32.0 0.255.3.255 echo
    60 permit icmp 10.0.32.1 0.255.0.0 10.0.32.0 0.255.3.255 echo-reply
    70 permit icmp 10.0.32.0 0.255.3.255 10.0.96.0 0.255.0.255 echo
    80 permit icmp 10.0.32.0 0.255.3.255 10.0.96.0 0.255.0.255 echo-reply
    90 permit tcp 10.0.32.0 0.255.3.255 10.0.96.0 0.255.0.255 eq 443
    100 permit udp 10.0.32.0 0.255.3.255 10.0.96.0 0.255.0.255 eq snmp
    110 permit tcp 10.0.32.0 0.255.3.255 10.0.96.0 0.255.0.255 eq 161
    120 deny ip 10.0.32.0 0.255.3.255 10.0.32.0 0.255.3.255 log
    130 deny ip 10.0.32.0 0.255.3.255 10.0.64.0 0.255.0.255 log
    140 deny ip 10.0.32.0 0.255.3.255 10.0.96.0 0.255.0.255 log
    150 permit ip host 10.105.34.9 10.0.112.0 0.255.0.255 log
    160 deny ip 10.0.32.0 0.255.3.255 10.0.112.0 0.255.0.255 log
    170 deny ip 10.0.32.0 0.255.3.255 10.0.114.0 0.255.0.255 log
    180 deny ip 10.0.32.0 0.255.3.255 10.0.161.0 0.255.0.255 log
    190 deny ip 10.0.32.0 0.255.3.255 10.0.165.0 0.255.0.255 log
    200 deny ip 10.0.32.0 0.255.3.255 10.0.235.0 0.255.0.255 log
    210 permit ip 10.0.32.0 0.255.3.255 10.0.240.24 0.255.0.0
    220 permit ip 10.0.32.0 0.255.3.255 10.2.240.0 0.0.1.255 log
    230 deny ip 10.0.32.0 0.255.3.255 10.0.240.0 0.255.0.255 log
    240 deny ip 10.0.32.0 0.255.3.255 10.0.241.0 0.255.0.255 log
    250 permit ip any any
Then if you want to add something at line 245:
R1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R1(config)#ip access-list extended 102
R1(config-ext-nacl)#245 deny ip host 1.1.1.1 host 2.2.2.2
Now it should be done:
R1(config-ext-nacl)#do show ip access-lists
Daniel Dib
CCIE #37149
Please rate helpful posts.
Daniel Dib CCIE #37149 Please rate helpful posts.
Silver
R1#conf t
Daniel Dib
CCIE #37149
Thank you.  It worked perfectly!
203
