08-27-2014 08:15 AM
How do I upgrade the bootloader on a Cisco SG200-50 GigaBit Smart Switch ?
Br. Torben Grosen
08-27-2014 10:06 AM
Short answer is you need to use a tftp server. Search the forum for many instructions. Here is one: https://supportforums.cisco.com/discussion/11953536/sg300-bootloader-upgrade
08-30-2014 12:36 AM
It works - Thanks a lot :-)
Have a nice weekend all :-)
08-27-2014 05:13 PM
Using TFTP Server:See below steps,
1. Make a backup of your config (just in case ... and CYA)
1. I upgraded the firmware using the web interface (.ros) file.
2. Apply or Activate and reboot
3. Your switch should reboot just fine.
4. To install the boot load (.rfb) you must use a TFTP server ...not sure why this is so.
If you don't have one - I suggest using TFTPF32 or 64bit version. I don't like the solarwind goons.
5. Hopefully you have some past history using FTP. It's really simple just stick the file into the upload/download folder of the TFTP server and you should be good to go.
6. Cisco SG WEB interface > Administration>File Managment> TFTP .... when you select TFTP the radio button for the "BOOT" fw is now available. Just type in the name of the file and it should load the boot firmware.
08-30-2014 12:35 AM
It works - thanks a lot :-)
Have a nice weekend all !!!
08-27-2014 05:26 PM
08-30-2014 12:36 AM
