Community Member
How do you configure a DHCP server's options for SMB 300 Switches for Auto Configuration?
I am looking for a how to configure a DHCP server for a Cisco SMB 300 series switch to obtain an automatic configuration. Currently i am using a Cisco 1800 router as my DHCP server and the DHCP pool serving the 300 series switch is configured as follows.
ip dhcp pool Cisco_SMB_300
   network 192.168.0.0 255.255.255.0
   default-router 192.168.0.1
   option 66 ip x.x.x.x
   option 67 ascii "config-file-name.txt"
   dns-server 8.8.8.8 8.8.4.4
** I've also tried option 150 .... "option 150 ip x.x.x.x"
Looking at pcaps, I don't even see a tftp request going the server after the switch obtains an IP via DHCP. The config file format is exactly as obtained from the download backup section (pretty sure its not the issue since i don't see a download attempt). Also, the SMB switch is running the latest firmware image (1.1.1.8)
Looking though the admin guide i did not see specifics on how the DHCP server was to be configure for the auto configuration feature to work. Any help is greatly appreciated.
George
Hi George, I hope this infomation will guide you in configuring your IOS router DHCP server.
---------------- ( excluded ip addresses - optional )----------------
ip dhcp excluded-address 192.168.110.1 192.168.110.3
ip dhcp excluded-address 192.168.110.225 192.168.110.254
---------------- (main DHCP pool scope for 192.168.110.0 /24) network ----
ip dhcp pool data110
   network 192.168.110.0 255.255.255.0
   default-router 192.168.110.1
   dns-server 206.13.29.12 206.13.30.12
   lease 0 0 15
---------------- ( static ip address mapping with option 150 and boot file ) ----
ip dhcp pool switch1
   host 192.168.110.4 255.255.255.0      <<<< switch1 ip address
   client-identifier 0188.43e1.ac8a.94      <<<< switch1 MAC address - please follow the format
   bootfile switch1                                 <<<< switch1 specific configuration
   option 150 ip 192.168.14.2                <<<< TFTP server ip address
   lease 0 0 15
ip dhcp pool switch2
   host 192.168.110.5 255.255.255.0
   client-identifier 0188.43e1.ac9b.34
   bootfile switch2
   lease 0 0 15
ip dhcp pool switch3
   host 192.168.110.6 255.255.255.0
   client-identifier 0140.f4ec.f34b.79
   bootfile switch3
Note: If you are not assigning ststic IP address and all devices will be sharing the same config
      file then you simply configure the main pool with the option
   lease 0 0 15
   bootfile file_name
   option 150 ip 192.168.14.2 10.2.1.1 1.1.1.1  <<<< please follow the ormat if you have multiple TFTP servers.
thank you.
Razmik
Community Member
Hello Razmik,
Two question,
1/ in provisioning of SPA phones, device looking automaticaly for .txt file, is there some option? like if i put $MAC.txt into "bootfile" option
2/ what is "bootfile" option by RFC? like "option 150", this config is Cisco IOS, i have for example Linux or Mikrotik
Tomas
Instead of option 150 , use next-server commad.
Its working for me
Cheers
Amit Dhanawade
2038
