how to block port communication
hi there,
           i have cisco sg-300 cisco switch. i want to make connections between 2nd to 3rd port, and block communication between 3rd and 4th port.
           in brief, 2nd port must access all other ports which is in same switch,, 3rd port should not communicate all other ports except 2nd port.
           and 4th port should not communicate all other ports except 2nd port....
          how to do this? is this possible.... please help...
Everyone's tags (7)
1 ACCEPTED SOLUTION
Green
Re: how to block port communication
Hi sundar, this can be done with protected port which is located by editing a port under port management. this will isolate every individual port from seeing each other while using the uplink port. If you need any of those AP ports to communicate then it will require access lists.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Green
Hi Sundar, this would be accomplished through access lists.
Remember the access list on this switch is for ingress traffic only so in other words if you want to block traffic from port 3 to port 2, the access list should be applied to port 3.
-Tom
Hi tom, thanks for the reply. but still i couldnt get the answer.
          Here i give you the brief.
i am going to connect 20 access point in that cisco sg-300 switch.
wifi users access the internet through access points which is connected to cisco sg-300 switch.
In order to reduce traffic in cisco sg-300 switch, i will assign port 1 as an uplink for internet.
port 1 (internet link)
port 2----access point 1---- wifi users(10 to 20 no's)
port 3---- access point 2-----wifi users (10 to 20 no's)
port 4----access point 3 ------wifi users (10 to 20 no's)
in this case port 2 and port 1 should be communicate,( to provide internet for wifi users's)
next            port 3 and port 1 should be communicate,(to provide internet for wifi users)
next            port 4 and port 1 should be communicate.(to provide internet for wifi users)
and now,
                port 2 and port 3 traffic must be blocked. (i dont know how to do this,, but i want to)
                 port 2 and port 4 traffic also must be blocked
                port 3 and port 4 traffic must be blocked.
that's all?
How to do this?
Green
-Tom
Thanks alot Tom,
            It works...!!!!!! :-)
1002
