how to configuration SG300-28 router by multi-Vlan?
why i can not found ip router setting by main menu?the sg300-28 can not support ip router command?mor informations,see my img.
If sg300-28 can not support ip router command,what i can do it that by multi-Vlan ?
thanks.
Everyone's tags (1)
1 ACCEPTED SOLUTION
Bronze
HI amin,
First you want to enable the Switch to Layer3 mode as explained below:
Upgrade the firmware to 1.1.2.0.Use the below link to download the firmware.
http://www.cisco.com/cisco/software/release.html?mdfid=283019686&softwareid=282463181&release=1.1.2.0&relind=AVAILABLE&rellifecycle=&reltype=latest
Configure the switch with below commands to change form Layer 2 to 3
The set system mode Privileged EXEC mode command puts the device into
switch mode (Layer 2 mode) or router mode (Layer 3 mode).
Syntax
set system mode {router | switch}
Parameters
• router—Specifies that the device functions as a switch-router.
• switch—Specifies that the device functions as a switch.
Default Configuration
The default configuration is switch mode (Layer 2).
Command Mode
User Guidelines
After executing the command, the Startup Configuration file is deleted and the
device is rebooted. It is highly recommended to back up the Startup Configuration
file before executing this command.
Example
The following example configures the device to function as a switch-router (Layer
3), with QoS and Policy based VLANs.
switchxxxxxx# set system mode router
After this
Kindly check the Menu--->IP configuration--->IPV4 interface---->you add the SVI interfaces for multi vlans.
regards
Moorthy
Bronze
HI amin,
Syntax
Parameters
Command Mode
User Guidelines
Example
After this
regards
Moorthy
Re: how to configuration SG300-28 router by multi-Vlan?
why sg300-28 can not  working at  router mode default,as sg300-28 support L3.
thanks Moorthy.
4097
