02-07-2017 03:41 PM
I have 2 stacked SG350XG 10GB switches that I need to have simple inter VLAN routing between VLANS. FW 2.0.0.73
I created 2 VLAN's and I created IP's on those VLAN's. I created trunk ports and untagged access ports assigned to the VLAN's.
I set up 2 laptops on untagged ports and tried to ping between the IP's and I get nothing. I've checked that routing is enabled, I can see the routes listed but I can't ping.I am able to ping between devices on the same VLAN.
The SG300's have a layer 2 mode and a layer 3 mode, adjustable in the admin system settings but I cannot see anything similar in the SG350XG web GUI. Is there something I am missing in the setup?
Does anyone have a suggestion on how to make this work?
02-07-2017 05:17 PM
can you ping from either PC to its respective IP address on the SG350XG?
if so, can you do an extended ping from the SG350XG's IP address in VLAN A to the PC in VLAN B?
cheers
02-08-2017 09:39 AM
Hi Dennis
Thanks for responding. After looking at your suggestions and my config again, I realized that I had left the wireless adapters on (but not connected) After disabling the wireless adapters I was able to ping each of the VLAN IP's from both laptops and each other. So it looks like I have a config that will work.
Thanks for your help
