Internet Routing with SG300-20 and a domain controller
I am trying to set up the SG300-52 and am struggling, I have a domain controller with IP address 192.168.0.1
I have a broadband router that is has a dynamc ip address. I have set up vlan1 aand vlan2
Vlan1 is getting its ip address from the domain which is 192.168.0.110
vlan2 is getting its ip from the broadband router.
I have setup Domain Name System in the Ip configuration tab
on Vlan1 I have a connected a dumb switch this connects all the computers in the local network. What I cannot get to work is the internet vlan.
Can someone who has setup up vlan routing with domain controller please help me
Silver
David,
First make sure you are running latest firmware on your SG300 switch. SW 1.1.1.8 code.
I take it that the broadband router does not support vlans; if this is correct then the SG300 switch will need to be placed in layer 3 mode. Basically your topology will look like a router on a stick configuration. You will need two separate subnets if you want to use two vlans’
Vlan 1 = 192.168.2.1
Broadband router = 192.168.2.254
Vlan 2 = 192.168.0.254
Domain controller = 192.168.0.1
You will need to add a default route within the SG300 switch
  • •0.0.0.0    0.0.0.0 192.168.2.254
Add another static route in broadband router
192.168.0.0 0.0.0.255 192.168.2.1
All device within your domain controller (vlan 2) network will have a GW of vlan2 (192.168.0.254) after setup is complete you should have access to the Internet and routable between both subnet's.
If you need further assistance please give us a call @ 1-866-606-1866 and open a support case And next available engineer will assist you. If i am available you can have the engineer consult with me.
Hope this helps
Jasbryan
Hi jasbryan
Thansk you for taking the time to reply unfortunately I did not manage to get it working, I think the broadband router I have is rubbish and will probable have to invest in a router to complete this task.
Could you recommend what router I should get, will a layer 2 router that is vlan aware be good enough. or will i need to get a layer 3 router.
Many Thanks
David
Silver
David,
Yes you will need a router that is Vlan aware for simplest configuration. Just an FYI when you're talking about routing/router all router's operate at layer 3. Below are lists of our router that supports 802.1Q Vlans.
RV120W
http://www.iplink.no/documents/RV120W-E-G5%20-%20Cisco.pdf
RV220W
http://www.cisco.com/en/US/prod/collateral/routers/ps9923/ps11025/data_sheet_c78-630461.pdf
Security appliance (what i use)
SA520W
SA520
SA540
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps6032/ps6094/ps9932/data_sheet_c78-542899.pdf
Hope this helps,
Jasbryan
Hi jasbryan
Thank you for the help so far
I bought a RV120W router which arrived today. its has numerous settings which I am not sure whether to change or not it is in DHCP server mode as a NAT gateway currently. It's ip address is 192.168.1.1
I assume I need to set to to router mode as I have added the default route in to the static route table
Here is the routing table from the RV120W after I plugged in the broadband router
Kernel IP routing table
Destination      Gateway        Genmask          Metric  Ref   Use      Interface      Type          Flags
127.0.0.1          127.0.0.1      255.255.255.255  1      0      0      lo               Static            UP,Gateway,Host
192.168.2.0      0.0.0.0          255.255.255.0      0      0      0      eth1          Dynamic        UP
192.168.1.0      0.0.0.0          255.255.255.0      0      0      0      bdg1          Static           UP
192.168.1.0      192.168.1.1   255.255.255.0      1      0      0      bdg1          Static           UP,Gateway
0.0.0.0             92.168.2.1    0.0.0.0                 0      0      0      eth1          Dynamic       UP,Gateway
as it is dhcp server mode should this be changed to dhcp relay,
Sorry for taking so much of your time but feel I am close to getting this working now
Regards David
Silver
David,
Please attach a topology view of your network (complete). I will give my recommendation on how I would configure device within your topology.
Jasbryan
Hi Jasbryan
Here is diagram of my network I have a lot more computers and servers which are connected to the unmanaged switch but did not think it was necessary to add them. To explain the diagram I have a broadband router connecting to a RV120W router this then connectes to Vlan3 on the switch, Vlan 2 is connected to the domain controller. What is confusing me is the additional of the new router between the broadband router and the switch. It looks like I ned to set up vlan routing on the router to route between the broadband router and the switch.
Thank you for assisting me with this.
David
1292
