Community Member
IOS upgrade issue
       I have cisco WS-C2960-24TC-L, I tried to upgrade the IOS from <c2960-lanbase-mz.122-53.SE2.bin > to <c2960-lanbasek9-mz.122-55.SE9.bin> , but it didn't work with new IOS, so I rolled back to the old one again, what may cause this problem and what's the proper upgrade procedures?
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
If you only have the BIN file
If you only have the BIN file, then it's as easy as copy the BIN file into the flash and change the boot string variable.
Can you elaborate what you mean by "it didn't work"?
VIP Purple
You could also upgrade the
You could also upgrade the Switch with the "archive" command. For that you need the tar-image and it's even easier than the manual copy of the bin-file.
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst2960/software/release/12-2_25_fx/release/notes/OL7076.html#wp45116
111
