Community Member
IP NAT / VLAN
Hi Guys,
My network consist of  5 VLANS. All vlans were map into a range of public ip (NAT).
My question is, is there a way where I can map a specific 1 VLAN into a 1 PUBLIC IP address?
Assuming my vlans are 192.168.1.0 /24 - 192.168.5.0 /24 and my public ip range is 200.1.1.0 /29
Can I map 192.168.1.0 /24 into 200.0.0.5 only?
Thanks in advance :)
I assume you are using Cisco
I assume you are using Cisco routers
so something like
ip nat source static network 192.168.1.0 200.1.1.1 /32
ip nat source static network 192.168.2.0 200.1.1.2 /32
ip nat source static network 192.168.3.0 200.1.1.3 /32
ip nat source static network 192.168.4.0 200.1.1.4 /32
ip nat source static network 192.168.5.0 200.1.1.5 /32
Richard
what product is this?
Bronze
If you want to map your
If you want to map your network 192.168.1.0/24 with one Public IP, please try the following:
access-list 1 permit 192.168.1.0 0.0.0.255
ip nat pool cisco 200.0.0.5 200.0.0.5
ip nat inside source list 1 pool cisco overload
Apply it to the concerned interfaces.
Community Member
Dear,Below configuration may
Dear,
Below configuration may help you.
interface Vlan1
 description CONNECTION TO LAN
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
 ip nat enable
ip nat inside source route-map fixed-nat1 interface FastEthernet0/0
access-list 110 permit 192.168.2.0 0.0.0.255 any
route-map fixed-nat1 permit 10
 match ip address 110
 match interface FastEthernet0/0
Note:* FastEthernet0/0 is a public ip configured inrterface
Raja
Community Member
Yes you can, if you have a
Yes you can, if you have a Public IP range, you can map your local ip range to public range.
Thanks.
256
