IPv4 Routing SG500x - Multiple default routes
I would like to add multiple default routes to the SG500x (1.3.7.18)
Scenario:
We have two wan links, one active, one failover.
The idea is to use the SG500x as a router for this, and route by default through the active interface, and in case this goes down, route through the failover interface.
However, the switch does not seem to accept multiple default routes
Additionally, it does not seem to be possible to set the Administrative Distance.
Any clues?
Michel
1 REPLY
I'm pretty sure you can't do
I'm pretty sure you can't do that with these switches.  You need a real ios switch or something else to handle failover like Cisco Meraki MX appliance.
-- please remember to rate and mark answered helpful posts --
108
