Issues with SRW2016: Boot2 Checksum Test ..... FAIL
My SRW2016 keeps rebooting after upgrading, I guess something went wrong...
He is what the console says:
------ Performing the Power-On Self Test (POST) ------
UART Channel Loopback Test........................PASS
Testing the System SDRAM..........................PASS
Boot1 Checksum Test...............................PASS
Boot2 Checksum Test...............................FAIL
Flash Image Validation Test.......................PASS
BOOT Software Version 1.0.1 Built  11-Jun-2006  18:43:59
Linksys SmartSwitch based on 88E6218 with ARM946E-S.
64 MByte SDRAM. I-Cache 8 KB. D-Cache 8 KB. Cache Enabled.
Autoboot in 2 seconds - press RETURN or Esc. to abort and enter prom.
Preparing to decompress...
100%Image in address: 0x0 - Check Sum error!
Please download a new image.
Downloading code using XMODEM.
Download failed
Perform WARM BOOT ...
I've tried loading firmwares srw2016-24-10086.ros, ls20xx_salsa-12222.ros and ls20xx-12230.ros but it doesn't want to take any of them.
Does anyone have a suggestion to solve this issue ?
Thanks.
Everyone's tags (1)
1 REPLY
Re: Issues with SRW2016: Boot2 Checksum Test ..... FAIL
This message is telling you to reload the boot code via xmodem. This post also deals with a similar issue:
https://supportforums.cisco.com/message/3103206#3103206
I recommend downloading the proper boot code and firmware for your switch, and then the admin guide. The boot code and firmware will be what you need to recover your switch and the admin guide will tell you how.
Bill
1090
