10-17-2010 03:15 AM
Hi all,
I have a problem to get lldp to work.
My setup is as follows:
Router (with lldp support) <----> Linksys SRW2008 <----> Workstation (with lldp support)
Querying lldp neighbors from my router show up only its own interfaces:
vyatta@vyt-node01:~$ show lldp neighbors
Capability Codes: R - Router, B - Bridge, W - Wlan r - Repeater, S - Station
D - Docsis, T - Telephone, O - Other
Device ID Local Proto Cap Platform Port ID
vyt-node01 eth2 LLDP R Vyatta Router eth0
vyt-node01 eth0 LLDP R Vyatta Router eth2
Querying lldp from SRW2008 do no show up anything:
cal-swge01-linksys# show lldp neighbors
Port Device ID Port ID System Name Capabilities
From the workstation nothing shows up.
I replaced the SRW2008 with a Surecom unmaned switch as follows:
Router (with lldp support) <----> Surecom switch <----> Workstation (with lldp support)
and from the router I see lldp informations from my workstation.
The question is, why the srw2008 block lldp traffic ? what do I hav to change on order to get lldp to work ?
Thnaks in advance
Roberto
12-19-2010 03:35 AM
it is not possible to enable lldp on linksys switches from the cli or webif.
But you can enable it using snmp. Here is a description (on a russian website).
http://www.opennet.ru/tips/info/2316.shtml
You must login to the cli and the configure snmp:
asw1# conf
asw1(config)# snmp-server community secret1 rw
Then you can enable lldp from an different computer:
snmpset -v2c -c secret1 1.3.6.1.4.1.3955.89.110.1.1.1.0 i 1
CISCOSB-LLDP-MIB::rlLldpEnabled.0 = INTEGER: true(1)
After enabeling this you shoud be able to see the lldp neighbours:
asw1# show lldp neighbors
6 01 c0 a8 0a b9 E80462EA4601:P1 SEPE80462EA4601.xxx B, T
x.xxxx.com
7 01 c0 a8 0a b5 000F23FCA5CC:P1 SEP000F23FCA5CC.xxx B, T
x.xxxx.com
Regards, Artem
12-20-2010 06:39 AM
Artem,
Thankyou for trying to help Roberto.
I had zero idea that the older SRW2008 (old switch model ), which has been replaced by the new SRW2008-K9-EU (300 series), could do LLDP MED.
I have no idea how you can put a older SRW2008 into CLI mode, to be able to enter the commands, as shown in the Russian website you referenced and in your example above..
The newer SRW2008-K9 (300 series) can natively via the GUI perform LLDP MED , but had no idea that the older product had that capability via a hidden and probably unsupported CLI interface.
Sounds a lot easier to move forward with a refreshed version of the SRW2008, the SRW2008-K9-EU
See the USA models and ordering part numbers at least at the following USA website, but also check locally in the Cisco Europe Website for refreshed (newer 300 series ) versions of the SRW series.
http://www.cisco.com/en/US/products/ps10898/prod_models_comparison.html
Thanks for your help for Roberto, a most interesting posting , if it works.
But anyway have a great holiday season and again thanks for your involvement in this website.
regards Dave
12-20-2010 06:57 AM
Hello David,
to enter the cli you must login to the switch using console, telnet or ssh.
When you see the "Configuration GUI" you must press Ctrl + Z.
Then you will get a prompt:
You can enter ? to see the options:
Unknown parameter
May be one from the following list:
debug exit help lcli logout mcli menu
then you can enter lcli and you must enter your credentials again.
>lcli
User Name:
User Name:admin
Password:***********
asw1#
And now you get an IOS like prompt.
asw1#
clear Reset functions
clock Manage the system clock
configure Enter configuration mode
copy Copy from one file to another
crypto Cryptographic commands
debug-mode Exit from the EXEC to debug mode
delete Delete a file from the flash file system
disable Disable privileged commands
dot1x 802.1x EXEC commands
exit Exit from the EXEC
help Description of the interactive help system
login Exit from the EXEC and Log in
no Negate command
ping Send echo messages
reload Halt and perform a cold restart
resume Resume telnet session.
set Set System Parameters
show Show running system information
telnet Open telnet session.
terminal Set current session functions
test diagnose
traceroute Discover the routes to destination
asw1#
asw1# conf
asw1(config)#
aaa Authentication, Authorization and Accounting is used
to manage user access to the system
arp Set a static ARP entry
bridge Global Bridge table configuration commands
class-map This command create class map and enter class map
configuration mode.
Use no form in order to delete the class.
crypto Global cryptographic features configuration subcommands
do execute an EXEC-level command
dot1x Global Configuration Commands for 802.1x
enable Modify enable password parameters.
end Exit from configure mode
exit Exit from configure mode
file-system File system configuration command
gvrp Global GVRP configuration commands
hostname Set system's network name
interface Select an interface to configure
ip IP configuration
lacp Global IEEE 802.3 link aggregation commands
line To identify a specific line for configuration
lldp Configure LLDP protocol
logging Configure message logging facilities.
mac MAC access lists commands
management IP management
no Negate command
policy-map This command create policy map and enter policy map
configuration mode. Use no form to delete the policy
map.
port switch ports configuration
power Configure the administrative mode of the inline power.
priority-queue Set priority queue parameters
qos Enable/Disable QoS on the device and enter the QoS
mode (advance/basic/service).
radius-server Modify RADIUS parameters
rmon Remote Monitoring (RMON) configuration subcommand
service Service commands.
snmp-server SNMP and system commands.
sntp Global Simple Network Time Protocol (SNTP)
spanning-tree Configure Spanning Tree Subsystem
tacacs-server TACACS server command
username Establish User Name Authentication.
vlan Vlan commands
wrr-queue Configure queue drop mechanism on egress port.
asw1(config)#
12-21-2010 01:15 AM
Hi Roberto, Artem, David!
This is unsupported features for old SRW-2008 platform.
LLDP with LLDP-MED and CLI will be available soon(Q1Y11) for new 300 series switches(SRW-2008-K9 for this case).
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps10898/data_sheet_c78-610061.html
Regards, Alexey Alexandrov
Cisco Systems Russia
SB SE
12-21-2010 07:13 AM
Hi AleAlexa,
thank you for your reply, I supposed it was not supported since I have found nothing about enabling LLDP support on this switch in this months
Thank you to Artem and David I learned something more about snmpwalk
