mac addresses of switchport
Hi all, How can i query the mac addeesses of a sg300 switch. I didn't find an apprpriate command in cli until now. i only see the base address.
Tom Watts
Hi Christian, the switch does not use mac address per switchport, only the system MAC.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom,
thanks. Can that be changed? I want to use Option 82 and figured out that the remote-id is the MAC address of the dhcp-relay agent. But with all the same mac it´s not possbile.
Christian
Hi Christian, no you cannot enable per port MAC. But I also do not see the need based on your comment. In layer 2 environment, DHCP-RELAY is not needed by the switch, in layer 3, option 82 is supported or you may use the switch as the DHCP server.
