Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
mac addresses of switchport
Hi all, How can i query the mac addeesses of a sg300 switch. I didn't find an apprpriate command in cli until now. i only see the base address.
Green
Hi Christian, the switch does
Hi Christian, the switch does not use mac address per switchport, only the system MAC.
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Hi Tom, thanks. Can that be
Hi Tom,
thanks. Can that be changed? I want to use Option 82 and figured out that the remote-id is the MAC address of the dhcp-relay agent. But with all the same mac it´s not possbile.
Christian
Green
Hi Christian, no you cannot
Hi Christian, no you cannot enable per port MAC. But I also do not see the need based on your comment. In layer 2 environment, DHCP-RELAY is not needed by the switch, in layer 3, option 82 is supported or you may use the switch as the DHCP server.
45
