need basic Help - SG300 with vlan and routing
i need some basic help with configuring vlan/routing.
Situation:
DSL Router - Cisco 300 - XenServer
192.168.1.253 - 192.168.1.19 - 192.168.1.10 (mgmt ip)
goal is, to reach from inside xenserver vms the internet.
vms = 192.168.2.x
gateway ip = 192.168.2.1
what i did:
- configured vlan 102, tagged, with the xenserver port
- configured on xenserver a network with vlan id 102, attached to the vm
- this network is conntected to an external bond
- configured ipva4 interface: vlan102 - Static - IP 192.168.2.1 (this is the gateway ip of the vms)
- automatic configured IPv4 Route: 192.168.2.0/24 next hop 0.0.0.0, Directly connected
So at the moment i cant ping from inside a vm to the DSL Router (192.168.2.2 to 192.168.1.253)
any ideas what i misconfigured or whats wrong?
cheers,
-Marco
Green
Hi Marcus, a route on the switch shouldn't be needed, that is redundant. You are missing a route on the router pointing back to the switch SVI.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Re: need basic Help - SG300 with vlan and routing
Hi Tom,
ok, that make sense. I can ping the router now inside vms from 192.168.2.x network.
But i cant ping external adresses, error: Destination net unreachable.
My other problem i have, i cant reach any server from outside over router portforwarding.
How do i have to configure the upload port to the dsl router? Is it a access port or a trunk
port with all vlans (tagged or untagged?) At the moment ive a tagged Trunkport with all vlans.
IPv4 Interface Table
InterfaceIP Address TypeIP AddressMaskStatus
VLAN 1Static192.168.1.19255.255.255.0 Valid
Should the VLAN1 ip adress not the router ip adress ? Do i need an additional vlan for
the router ? At the end i like to change the switch ip from dhcp to static (change automaticly
when switching to layer 3 mode), but ive to look for the ios commands first.
What else do i missing ?
Thanks a lot,
Marcus
Green
Hi Marcus, please reference this post it should template everything you need for success.
https://supportforums.cisco.com/thread/2123434
-Tom
Hi Tom,
ok, i managed to reconfiger VLAN 1 to a ip adress i want to.
I can see, when i add a ipv4 Default Route through cli and System Configuration Menu
it works. I can ping from inside vms over the dsl router to internet. But for some reasons,
also when i try to save the running config via web gui or clie (copy run start) after a reboot
this default gateway is gone. Also iam not sure, is this configuration is common.
Thanks a lot again,
-Marcus
Green
Hi Marcus, gone in the sense it is broken or gone in the sense that it's a cosmetic issue?
-Tom
427
