Need to connect Vlans from asa 5510 to sg300 switch
HI,
This is the running config for sg300
switcha86a4c#sh running-config
config-file-header
switcha86a4c
v1.3.0.62 / R750_NIK_1_3_647_260
CLI v1.0
set system mode switch
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
hostname switcha86a4c
username cisco password encrypted ffbfd6065116dea396bdb03476f77ef737cc31de privilege 15
More: <space>, Quit: q or CTRL+Z, One line: <return>
ip ssh server
snmp-server server
and cisco Asa running configuration:
ciscoasa# sh running-config
: Saved
ASA Version 9.1(3)
hostname ciscoasa
enable password xxxxxxxxxxxxxxxx encrypted
passwd xxxxxxxxxxxxxxx encrypted
names
interface GigabitEthernet0/0
nameif WAN
security-level 0
ip address x.x.x.x 255.255.255.248
interface GigabitEthernet0/1
nameif LAN
security-level 100
ip address 192.168.0.1 255.255.255.0
interface GigabitEthernet0/2
nameif LAN-2ndFloor
security-level 100
ip address 192.168.2.1 255.255.255.0
interface GigabitEthernet0/3
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/4
shutdown
no nameif
no security-level
no ip address
interface GigabitEthernet0/5
shutdown
no nameif
no security-level
no ip address
interface Management0/0
management-only
nameif management
security-level 100
ftp mode passive
dns domain-lookup LAN
dns domain-lookup LAN-2ndFloor
dns server-group DefaultDNS
name-server 192.168.0.8
same-security-traffic permit inter-interface
same-security-traffic permit intra-interface
object network obj-wan
subnet 0.0.0.0 0.0.0.0
object network WAN-network
host x.x.x.x
access-list LAN_access_in extended permit ip any any
access-list LAN-2ndFloor_access_in extended permit ip any any
pager lines 24
logging enable
logging asdm informational
logging from-address xxxx@gmail.com
logging recipient-address xxxx@gmail.com level errors
mtu WAN 1500
mtu LAN 1500
mtu LAN-2ndFloor 1500
mtu management 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (LAN,WAN) source dynamic any interface
nat (LAN-2ndFloor,WAN) source dynamic any interface
access-group LAN_access_in in interface LAN
access-group LAN-2ndFloor_access_in in interface LAN-2ndFloor
route WAN 0.0.0.0 0.0.0.0 183.82.41.49 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
user-identity default-domain LOCAL
aaa authentication http console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart warmstart
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpoint _SmartCallHome_ServerCA
crl configure
crypto ca trustpool policy
crypto ca certificate chain _SmartCallHome_ServerCA
certificate ca 6ecc7aa5a7032009b8cebcf4e952d491
308205ec 308204d4 a0030201 0202106e cc7aa5a7 032009b8 cebcf4e9 52d49130
0d06092a 864886f7 0d010105 05003081 ca310b30 09060355 04061302 55533117
30150603 55040a13 0e566572 69536967 6e2c2049 6e632e31 1f301d06 0355040b
13165665 72695369 676e2054 72757374 204e6574 776f726b 313a3038 06035504
0b133128 63292032 30303620 56657269 5369676e 2c20496e 632e202d 20466f72
20617574 686f7269 7a656420 75736520 6f6e6c79 31453043 06035504 03133c56
65726953 69676e20 436c6173 73203320 5075626c 69632050 72696d61 72792043
65727469 66696361 74696f6e 20417574 686f7269 7479202d 20473530 1e170d31
30303230 38303030 3030305a 170d3230 30323037 32333539 35395a30 81b5310b
30090603 55040613 02555331 17301506 0355040a 130e5665 72695369 676e2c20
496e632e 311f301d 06035504 0b131656 65726953 69676e20 54727573 74204e65
74776f72 6b313b30 39060355 040b1332 5465726d 73206f66 20757365 20617420
68747470 733a2f2f 7777772e 76657269 7369676e 2e636f6d 2f727061 20286329
3130312f 302d0603 55040313 26566572 69536967 6e20436c 61737320 33205365
63757265 20536572 76657220 4341202d 20473330 82012230 0d06092a 864886f7
0d010101 05000382 010f0030 82010a02 82010100 b187841f c20c45f5 bcab2597
a7ada23e 9cbaf6c1 39b88bca c2ac56c6 e5bb658e 444f4dce 6fed094a d4af4e10
9c688b2e 957b899b 13cae234 34c1f35b f3497b62 83488174 d188786c 0253f9bc
7f432657 5833833b 330a17b0 d04e9124 ad867d64 12dc744a 34a11d0a ea961d0b
15fca34b 3bce6388 d0f82d0c 948610ca b69a3dca eb379c00 48358629 5078e845
63cd1941 4ff595ec 7b98d4c4 71b350be 28b38fa0 b9539cf5 ca2c23a9 fd1406e8
18b49ae8 3c6e81fd e4cd3536 b351d369 ec12ba56 6e6f9b57 c58b14e7 0ec79ced
4a546ac9 4dc5bf11 b1ae1c67 81cb4455 33997f24 9b3f5345 7f861af3 3cfa6d7f
81f5b84a d3f58537 1cb5a6d0 09e4187b 384efa0f 02030100 01a38201 df308201
db303406 082b0601 05050701 01042830 26302406 082b0601 05050730 01861868
7474703a 2f2f6f63 73702e76 65726973 69676e2e 636f6d30 12060355 1d130101
ff040830 060101ff 02010030 70060355 1d200469 30673065 060b6086 480186f8
45010717 03305630 2806082b 06010505 07020116 1c687474 70733a2f 2f777777
2e766572 69736967 6e2e636f 6d2f6370 73302a06 082b0601 05050702 02301e1a
1c687474 70733a2f 2f777777 2e766572 69736967 6e2e636f 6d2f7270 61303406
03551d1f 042d302b 3029a027 a0258623 68747470 3a2f2f63 726c2e76 65726973
69676e2e 636f6d2f 70636133 2d67352e 63726c30 0e060355 1d0f0101 ff040403
02010630 6d06082b 06010505 07010c04 61305fa1 5da05b30 59305730 55160969
6d616765 2f676966 3021301f 30070605 2b0e0302 1a04148f e5d31a86 ac8d8e6b
c3cf806a d448182c 7b192e30 25162368 7474703a 2f2f6c6f 676f2e76 65726973
69676e2e 636f6d2f 76736c6f 676f2e67 69663028 0603551d 11042130 1fa41d30
1b311930 17060355 04031310 56657269 5369676e 4d504b49 2d322d36 301d0603
551d0e04 1604140d 445c1653 44c1827e 1d20ab25 f40163d8 be79a530 1f060355
1d230418 30168014 7fd365a7 c2ddecbb f03009f3 4339fa02 af333133 300d0609
2a864886 f70d0101 05050003 82010100 0c8324ef ddc30cd9 589cfe36 b6eb8a80
4bd1a3f7 9df3cc53 ef829ea3 a1e697c1 589d756c e01d1b4c fad1c12d 05c0ea6e
b2227055 d9203340 3307c265 83fa8f43 379bea0e 9a6c70ee f69c803b d937f47a
6decd018 7d494aca 99c71928 a2bed877 24f78526 866d8705 404167d1 273aeddc
481d22cd 0b0b8bbc f4b17bfd b499a8e9 762ae11a 2d876e74 d388dd1e 22c6df16
b62b8214 0a945cf2 50ecafce ff62370d ad65d306 4153ed02 14c8b558 28a1ace0
5becb37f 954afb03 c8ad26db e6667812 4ad99f42 fbe198e6 42839b8f 8f6724e8
6119b5dd cdb50b26 058ec36e c4c875b8 46cfe218 065ea9ae a8819a47 16de0c28
6c2527b9 deb78458 c61f381e a4c4cb66
quit
telnet 192.168.0.0 255.255.255.0 LAN
telnet timeout 30
ssh 192.168.0.0 255.255.255.0 LAN
ssh timeout 30
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd address 192.168.0.10-192.168.0.190 LAN
dhcpd dns 192.168.0.8 interface LAN
dhcpd enable LAN
dhcpd address 192.168.2.2-192.168.2.254 LAN-2ndFloor
dhcpd dns 123.176.37.37 8.8.8.8 interface LAN-2ndFloor
dhcpd enable LAN-2ndFloor
dhcpd address 192.168.1.2-192.168.1.254 management
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
username cisco password ffIRPGpDSOJh9YLq encrypted privilege 15
cxsc auth-proxy port 1025
class-map inspection_default
match default-inspection-traffic
class-map global-class-cx
match any
class-map global-class-cy
policy-map type inspect dns preset_dns_map
parameters
message-length maximum client auto
message-length maximum 512
policy-map global_policy
class inspection_default
inspect ftp
inspect h323 h225
inspect h323 ras
inspect rsh
inspect rtsp
inspect esmtp
inspect sqlnet
inspect skinny
inspect sunrpc
inspect xdmcp
inspect sip
inspect netbios
inspect tftp
inspect ip-options
class global-class-cx
cxsc fail-open monitor-only
class class-default
user-statistics accounting
policy-map pm_shaper
class class-default
service-policy global_policy global
prompt hostname context
call-home reporting anonymous
hpm topN enable
Cryptochecksum:1850e04159a3dad74307f62df14e4f96
: end
Kindly help if you can. i have tried to create subinterface in it but no connection between asa switch has taken place:
interface GigabitEthernet0/2.10
Vlan 10
nameif LAN-2ndFloor
security-level 100
All assistance would be appreciable. Even from asdm and sg300 gui mode too.
1 REPLY
If someone knows this better kindly help me am in bit hurry
Please I am in middle of configuring this something.
18
