Newbie L3 Route need help
Hi all,
I have a SG300-28 setting on L3 Mode, and it VLAN1  IP is 192.168.218.3 255.255.255.0
On top of this, have a router, it LAN VLAN 1 IP is 192.168.218.1 255.255.255.0
When I login on the SG300-28 Administration > Ping or Traceroute, it never pass to outside (The 192.168.218.1 there)
Here are my setting Screen Capture of my SG300-28
http://explorerhome.dyndns.org/q/SG300-28_002.jpg
http://explorerhome.dyndns.org/q/SG300-28_003.jpg
It look like on L3 Mode haven't any thing let me set the default gateway to 192.168.218.1 ...
Anyone who good at route can teach me? Also one more question, what addition setting for the VLAN 77, 78 IP default gateway setting that can let the computer there can go out the internet?
Thank you very much of your time and help.
Best Regards,
Jimmy Chan
Gold
Hi Jimmy,
From the switch can you ping the router at 192.168.218.1?
You should be able to get out since 192.168.218.1 is directly connected and in the same VLAN.
For the other VLANs you will need to create a static route in the router that points to the switch. Example:
To get to 192.168.78.0, go to 192.168.218.3
To get to 192.168.77.0, go to 192.168.218.3
- Marty
Re: Newbie L3 Route need help
Hi mpyhala,
Yes, in the switch page by using Ping Tool it can ping the 192.168.218.1 on the above GW.
but if I change to by name, it show me DNS error.
Now here are my screen setting of it and result for your kindly reference.
My FULL Network
http://explorerhome.dyndns.org/q/SG300-28_Network.jpg
Ping Test Error
http://explorerhome.dyndns.org/q/SG300-28_004.jpg
http://explorerhome.dyndns.org/q/SG300-28_005.jpg
http://explorerhome.dyndns.org/q/SG300-28_006.jpg
http://explorerhome.dyndns.org/q/SG300-28_007.jpg
I am also wonder why it route NEXT HUB is 0.0.0.0? why it is not 192.168.218.1 ?
Thank you again of your value time and help for me.
Best Regards,
Jimmy Chan
Hi all,
I fix it by login to CLI ...
then run this
config t
ip default-gateway 192.168.218.1
This make the L3 Switch have a default gateway and add a static route table in it.
Cisco Small Business much take care of their Admin and User Guide. Just all text without real life example and image is not good for Small Company without IT.
386
