Community Member
no 'ip routing' command on switch and yet intervlan routing.
In my companies 4500 switch I see there is intervlan routing configured for the 4 Vlans it has but I do not see any 'ip routing' command on it
to enable routing on the switch. Can a switch route even though the command isnt there?
1 ACCEPTED SOLUTION
Community Member
Ninja,
Default configuration options often do not show up in "show run".  Please try "show run all".
Christopher
PS Your switch is and Enterprise device, not Small Buisness.
Community Member
Ninja,
Christopher
Community Member
Ran the 'show run all' command and it was there. Thought '
sh run | i ip' would display it but didn't.
Thanks for the command.
We just turned enterprise. I keep forgetting that.
655
