Not able to change SF300-8 port switch management VLAN ID
Hi, I recently upgraded SF300-8 port switch firmware to 1.2.9.44 version. Now I am not getting option to change management VLAN to other vlan(say vlan 20) since it is only displaying default vlan (VLAN1). Can any one help to change management VLAN ID from default vlan ID
Green
Hi Tech, it should be the same, changing the default VLAN to 20.
In the cli it would be
config t
vlan database
default-vlan 20
Then the switch would also require a reboot since this change can't take effect until then.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
You need an interface (which's up) in the new VLAN Management to do that
Without it, you can't change the VLAN Management (in Web GUI)
Boris
597
