Please which are the small business CORE switches?
Please which are the cisco small business Core and Edge switches?
Re: Please which are the small business CORE switches?
In fact, since small-business networks are:
a) small; and
b) frequently single-site; or
c) not in possession of their own WAN infrastructure even if they are multi-site
.... the Cisco advice on campus-hierarchical and enterprise-modular designs goes out the window in the small business product range.  This is not frequently a problem in practice - the LAN at each site will be fairly 'flat' anyhow - very likely the same switch will fulfil the role of access for the server farm, user workstations, phones and printers ... as well as being directly connected to the WAN/edge device.
This single-switch arrangement works out fairly well in most deployments, and there is a switch to meet your needs and budget.
Well, most of your needs.  It's a small security concern that Layer 2 broadcasts from user-facing ports are flooded to server-facing ports.  Because the chowder-heads at Cisco won't allow inter-VLAN (static Layer 3) routing on any of their switches (except the ex-Linksys ones which have no future), you can't put servers and workstations in separate VLAN's unless you want it badly enough to do router-on-a-stick using another device (and why would we want to do that, Cisco?  It performs worse and it costs more.)
Hope that helps,
David.
Check out the below link Hope to help !!
https://www.cisco.com/en/US/products/ps9994/index.html
https://www.cisco.com/en/US/products/ps9967/index.html
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
1988
