PoE and Non PoE
nelba_aldovino
Hi all,
Just want to ask if it is possible to connect a cisco PoE switch to a cisco Non PoE switch?
The core switch will be a cisco Non PoE switch while the connected switch is a cisco PoE switch.
thank you....
You can disable PoE on an interface by invoking the command "power inline never".
Please don't forget to rate useful posts.  Thanks.
Leo Laohoo
Yes.  IT's possible.
Is there will be no problem encountered with it?
Just want to be sure because we plan to have and implement it.
Another is there an option to disable it's PoE?
thank you
Leo Laohoo
Thank you very much for the ratings.
