Port security and DHCP
Hello all.
I have configured port security in a couple of ports and I don't think it handles the frames as it should. the settings are the following
- max: the proper number of MAC adds
- mode secure permanent
- discard
I connect the legitimate devices in order to learn the maximum number of MACs the port should learn and then I connect a device with non secure MAC. I can obtain an IP from the DHCP server but then no traffic is being forward. I think that the non-legitimate device should not be able to obtain an IP since port security discards all frames with an unknown source MAC.
1 ACCEPTED SOLUTION
Hi Stelios,Your configuration
Hi Stelios,
Your configuration seems to be just fine. Mine was related only to port security and max addresses I set to 1. I saw that only 1st MAC address is sending bootp any other devices connect through the switch on this port are not sending bootp.
You might also do packet capture using switch port mirroring capabilities and wireshark application. Perhaps devices are using old known IP addresses...
Aleksandra
Hi Stylianosvlachakis,Hard to
Hard to comment without knowing what the switch model is and what the switch configuration is.
Hello dargielThe port
Hello dargiel
The port security configuration is exactly the one I put above. more commands include IP source gurad, switchport mode access and the vlan assignment, spanning tree bpduguard and portfast.
Model SG50052
Hi Stelios,I am running 1.4
Hi Stelios,
I am running 1.4 firmware and boot code and cannot recreate the problem. Perhaps my setup is different than yours, I would suggest you to call Cisco Small Business Support team and open the ticket:
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
If there is something unexpected in the switch behavior this is the right way to report this.
Aleksandra
Hello Aleksandra.Thanks for
Hello Aleksandra.
Thanks for your kind help. I will the support team for a ticket. Just in case I am missing something I will post the relative parts of the configuration here. The port I am talking about at the first post is member of VLAN 16.
ip dhcp snooping
ip dhcp snooping database
ip dhcp snooping vlan 16
ip arp inspection vlan 16
ip source-guard
interface gigabitethernet1/1/1
 port security max 9
 port security mode secure permanent
 spanning-tree portfast
 switchport access vlan 16
Hi Stelios,
Aleksandra
Thanks for your replies and
Thanks for your replies and help kind lady.
The IPs that are assigned to machines are definitely fresh, cause I 've readdressed the network, so there is no way to have such an old known.
I will go through tech-support.
My best
Stelios
One last question: What
One last question: What should I have done prior contacting Cisco Support ? I mean in terms of registration etc.
Thanks in advance.
Hi Stelios,You should prepare
Hi Stelios,
You should prepare Cisco ID (username to login on cisco.com) and serial number of the switch and call number in your country:
you can share with me the case number via private message.
Aleksandra
100
