Problem in SG300 POE 28 port
Dear
i have problem in Poe port i have Access point TP link tl-wa5110g High Power when i bluged in switch i can`t take power from switch
note Acess point support Poe in put power 12V 1 A
thanks..
Green
Hi Kareem, I may be defficient but I do not see POE specification for this AP?
http://www.tp-link.com/en/products/details/?model=TL-WA5110G#spec
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Dear Mr Tom
Thanks For reply but this device work poe
HARDWARE FEATURES
InterfaceOne 10/100M Ethernet Port(RJ45)
Support Passive PoE
and with this device with packge Converter and i try to connect this device by converter work fine but when i put in my switch don`t work
thanks..
Green
Hi Kareem, the passive poe is not considered a standard under 802.3af since it does not have an active component. Passive POE tries to use unused wires for power.
I can only recommend you use some sort of injector to standardize your POE to be 802.3af compliant.
-Tom
Dear Mr Tom
Thanks Soo Much for you support which moudel supported for my switch did you frefer
Thnaks..
Green
Hi Kareem any 802.3af injector should be compatible to the switch. I'd recommend to call the AP vendor and ask them what 802.3af injector is compatible to their product.
-Tom
787
