04-09-2013 05:31 AM
Bonjour / Hello
je dois remplacer une sge2000p par un produit ayant plus de port disponible. i need to replace a sge2000p by another one with more port available. Cet équipement est le ID3 d'une grappe empilable que je veux conserver. This equipment is the ID3 of stackable group and i will to keep it.
Quel produit est compatible avec le modèle que j'utilise ? Which product is compatible with the one i use.
Merci / Thanks
04-11-2013 08:10 AM
Good morning
Hi Eric, thanks for using our forum, my name is Johnnatan and I am part of the Small business Support community. How many ports so you need? You can see the different models here. You can compare the switches, there are many types of them, Gb or Mb, 24 ports or 48 ports etc.
I hope you find this answer useful,
“Please rate useful posts so other users can benefit from it”
Greetings,
Johnnatan Rodriguez Miranda.
Cisco Network Support Engineer.
04-11-2013 08:56 AM
Hello Jonathan. thanks for you're reply. i've more than 40 sge2000p switch on 6 million square feet space. The network is separate in 10 different subnet. Each subnet have more than 3 stackable switch connected together by mgblh1 sfp. ( yes the same sfp for mono and multimode fiber). all subnet are connecter in Gb. all subnet switch are connected in ring topology. if the middle switch go down, the latest one is always connected with ring connection.
Now one of my bulding will require more ethernet port. my wall cabinet cannot accept another sge2000p switch. i need to replace by a 48 ports because physical space limit. i would like to obtain a switch compatible with my sge2000p for stacking.
5 years ago, when a purchasse this model from linksys. nobody at cisco and nobody at no!"/$%? believe this stacking capacity ( by gbic port) . maybe this reason why cisco purchasse linksys switch after that
04-15-2013 09:09 AM
That would be the SGE2010P
However the SGE2000 is End Of sales and you might want to look into the successor: http://preview.tinyurl.com/chzfost
I suggest to replace the whole stack with the SG500 series, which provides more features and better stacking (i.e. 5 Gig stacking capacity). SGE2000 stacking is not compatible with SG500 stacking
