Community Member
Remote SSH sessions disconnecting after idle time.
We have recently shifted to Cisco RV325 as our primary router for office. After the installation our remote ssh connections are disconnecting after some idle time. ?  Any suggestion on how to fix it!!!
Community Member
On a RV320 you can change the
On a RV320 you can change the session timeout period at >Setup>Passwords>Session Timeout at the bottom of the page.
Community Member
Great Job Viningele.Ali Bin
Ali Bin Akhtar
Hi Ahmed,Vinigel mentioned
Hi Ahmed,
Vinigel mentioned session timeout setting which are related to the https access to the router management interface. I believe you have a problem with SSH passthrough.
If this is the case, it is not something which can be done by the user so please contact our Small Business Support Center and open ticket:
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
Aleksandra
Community Member
Hussnain,The latest version
Hussnain,
The latest version of the firmware for the RV320/RV325 includes support for user configurable TCP/UCP timeout sessions
Version 1.2.1.13
http://www.cisco.com/c/dam/en/us/td/docs/routers/csbr/rv320/release_notes/rv32x_relnote_v1_2_1-13.pdf
https://software.cisco.com/download/release.html?mdfid=284005936&softwareid=282465789&os=&release=1.2.1.13&relind=AVAILABLE&rellifecycle=&reltype=latest&i=!pp
Russ
304
