Routing vlan traffic out from SGE2000P
We have one SGE2000P switch that we are testing in Layer 3. We have a very simple configuration with some vlans that we want to route to our corporate network, but I want to test if there is actually traffic coming out from the up-link port first.
1- Created the vlans:
VLAN1:     10.10.1.12 /16 (native)
VLAN10: 172.16.10.1 /24
VLAN20:  192.168.0.1 /24
2- Assigned ports to VLans:
Port g3 is in Vlan 10
Port g22 is in Vlan 20
Port g1 is by default on Vlan 1 (native)
3 - Connected PCs to Vlans:
PC connected at g3 has Vlan 10 IP as gateway (172.16.10.1)
PC connected at g22 has Vlan 20 IP as gateway (192.168.0.1)
4 - Looks like intervlan routing is working 'cause both PCs can ping each other.
5 - I added a default route to another testing machine's IP, ie, 0.0.0.0 /0 10.10.0.1 connected to port g1, but the ping doesn't work.
Now the questions:
1 - How can I test if there is traffic being routed to port g1 from the vlans ???
2 - What else do I need to add in the switch config to take traffic out from the vlans to Port g1 ???
For reference, the sw's running-config:
console# show running-config
vlan database
vlan 10,20
exit
interface ethernet g3
switchport access vlan 10
exit
interface ethernet g22
switchport access vlan 20
exit
interface vlan 1
ip address 10.10.1.12 255.255.0.0
exit
interface vlan 10
ip address 172.16.10.1 255.255.255.0
exit
interface vlan 20
ip address 192.168.0.1 255.255.255.0
exit
ip route 0.0.0.0 0.0.0.0 10.10.0.1
console#
Any help / comment is much appreciated.
Thanks in advance,
jose
1 REPLY
Bronze
Hello Jose,
In order for a vlan to be active, you will have to have something connected to a port on that vlan. In this case you should be able to add a PC to port g1 and set it to be 10.10.1.1 with gateway of 10.10.1.12.
If you are looking to add a router in place as the main way out to the internet, you will:
have to have the router IP be 10.10.1.1
add a static route in the router for each subnet pointing back to 10.10.1.12
With the ip route already in there for 0.0.0.0 to 10.10.1.1, you should be able to get online.
622
