sa 540 + sg 200-26 intervlan routing
hello guys
I am trying to set up this thing, I managed to configure the intervlan routing and vlan tagging in the router itself (with its built in switch)
the next step was
1) created the same vlans with the same ids in the switch (Since it doesnt have VTP)
2) set up two ports in the switch , one for each vlan in in general mode and then one in trunk mode to a router port which is also in trunk mode(port 6 SW > port 1 of router) , both trunk ports are members of the vlans involved
3) at that point , I cant ping anything, say a host in a different vlan
I made some packet capture in the router and it seems the router sees the requests but not the replies , it seems as if it simply doesnt want to forward the reply for some reason
at a total lost at this point and its not encouraging that I see so many posts about bugs in the firmware
router and switch are both running the latest version
I am sure I am doing something totally basic......in a totally incorrect way
Please help
Thanks in advance
1 REPLY
Re: sa 540 + sg 200-26 intervlan routing
Thank you for the excellent images.
Firstly make sure the switch is using the most curent firmware 1.1.1.8  and the SA540 is using the most current firmware 2.1.51
May pay you to read the release notes of caveats on upgrading the SA540.
http://www.cisco.com/en/US/docs/security/multi_function_security/multi_function_security_appliance/sa_500/release/sa500_MR4_v2.1.51.pdf
I can see that the router SA540  has untagged VLAN 1 frames going out port 1 and tagged ethernet frames for the other VLANs being propogated out port 1.  SA540 looks like it is correctly setup, but the switch is not the way i would set it up.
If GE6 on the switch is the uplink port  to the SA540, try the following to get those VLANs propogated in and out of the switch.
Leave Switch port GE6 as the uplink ports to the SA540, if that is what you want.
If you do this tthen  connect only one CAT5e or CAT6 cable between GE6 of the switch to Port 1 of the SA540..
On the switch;
1. Set GE6 back to the VLAN Interface mode of trunk mode (default)
2. add the other  extra vlans 4,5,6,7 etc.. as tagged vlans onto GE6
Add other switch ports as untagged members of the vlans as required.
Now check connectivity.
( there is probably no reason to alter the default VLAN interface mode from trunk to any other mode)
let me know how it goes.
regards Dave
2028
