SF300 Inter-Vlan Communication
I have read over quite a few of thes, and either can't seem to find my answer....OR can't recongize that was my answer!
I have 2 vlans, vlan1 (secure) vlan2 (guest wifi).  Vlan1 is getting ip from DHCP server 10.10.11.x.  Vlan2 is getting IP from DHCP server  10.10.12.x.  The gateway for the internet lies in vlan1's scheme of 10.10.11.254.  I need to get internet to the vlan2 guest wifi people, but not give them access to all the internal secure stuff in vlan1.
I can't just connect another switch ot teh cisco 891 router becasue all internet traffic needs to run through the IPRISM filter we are using.
I'm new to vlans, and just need to know how to get vlan2 on the internet.
thanks ahead of time, John
  • Small Business Switches
Everyone's tags (4)
Green
Hi John, I suspect you read over the answer but didn't quite recognize it
One of two things has to happen.
1- Your switch remains in layer 2 mode (by default) and you create a trunk between the switch and the router for vlan 1 untagged, vlan 2 tagged
or
2- You change the switch in to layer 3 mode, create the IP interfaces and then create a static route on your router pointing back to the SVI of the switch to make the router aware of the second subnet.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Re: SF300 Inter-Vlan Communication
ok...thank you so much for replying.
I currently have the swtich in L3.  Here is a basice setup of what i have plugged in where.
WAP = FE24, 10.10.11.4, vlan1, tagged vlan2.
DHCP = GE2, 10.10.11.1 vlan1, tagged vlan2
Webfilter = FE2, 10.01.11.18, no vlan (native 1 i guess)
Router is at 10.10.11.254, HOWERVER is only accessable through the webfilter.  (cable connects switch to filter, then filter out to router)  Its a Cisco 891.
So i know i need to do option 2, just don't really understand how.
thanks again
John
under IPv4 static routes,  i have 1 entry
destination 0.0.0.0, prefix 0, type remote, next hop 10.10.11.254, owner static, metric 1
Ok, so i put in a default route in the router for 10.10.12.0 255.255.255.0 10.10.11.11
and now it seems to be working!!  YEAH...BUT i have one issue real quick
i dont' want it to be able to ping the server on the 10.10.11.x network.  I set the DHCP dns to be 8.8.8.8 for that network.  But, when i tried pinging dc1 (10.10.11.1) it responded on an IPV6 response address.  So, somehow the 10.10.12.x vlan is DNS aware of the 10.10.11.x vlan, and can talk to it.
Can i keep that from happening?
Green
Hi John, the switch in layer 3 mode automatically builds the routes for different vlans and subnets to communicate. If your goal is to separate the network for 2 distinct vlans but maintain the internet access then an access list of the switch must be created.
The access list is ingress only (inbound to the port). Meaning if you have Client in subnet B connecting to port 1 and a server in subnet A connecting to port 2, to prevent that client from hitting that server you'd need an access list applied to port 1.
-Tom
475
