SF500-24 combo ports for ethernet access
Good afternoon cisco community,
I have some cisco switchs (SF500-24), and I found that the 21 and 22nd ports and combo (ethernet and SFP), and when I try to connect a PC on any one of these ports , it does not work correctly.
I planed to link the SF500-24 switches with a catalyst 2960 XR using the 21 and 22nd ports, but it also doesn't work.
Also when I check in the management web interface, these 2 ports are not shown.
So How can I make them work properly as the other ports ?
Best regards,
  • Small Business Switches
Everyone's tags (3)
Hello,I would recommend you
I would recommend you to put switch in standalone mode (stacking is by default) and test it having in mind that combo ports are really just 1 port inside and SFP has higher priority than cooper.
Please let me know how it goes.
Aleksandra
Adargiel,By change the switch
Adargiel,
By change the switch to standalone mode does that clear the config on the other ports?
Greg
Hi Greg,It actually deletes
Hi Greg,
It actually deletes startup configuration file.
So I would recommend you to make a copy before and re-apply after, via CLI if you feel comfortable with this.
Aleksandra
126
